hillbillyrc
Added xr mod the steering section
Gen2 I'm unsure but I know this will work and a couple bucks cheaper to boot.
https://www.hobbytown.com/barrage-aluminum-rear-hub-carrier-2-by-ecx-ecx312005/p539121
Gen 2 axles and gen 1 axles axle housing and shafts are only different
Nice find and 12.99 for front and rear bumper mounts is a deal.
What's Included:
1x Front and Rear Bumper Mount for ECX Barrage
And everywhere else on that page it says both.
That's a big typo.
Thanks for clarifying this, hobbyjumper. I attempted to drill out pinion from a smaller 370 motor shift to fit the 390 shaft, but the bit walked and drilled off center. So much for that.As seen in my build video, this pinion fits the 390 shaft, so 2.3mm. I found the torque increase meaningless, and the noise unacceptable. Went back to the stock.
Traxxas 7041 18-T Pinion Gear, 48P (2.3mm shaft)
Cheers, Pete
Cheers, Pete
Anyone have luck with finding parts anywhere? Specifically looking for lockers and frame rails but it looks like everything is out of stock / discontinued.
Locker have been hard to find for a long time. I seen a frame rail set on eBay but the front was like a scx10. When the stock is not.
