HB Rover Review
I just ordered mine in a med. compound. I was woundering if anyone is running the med? What foam setup you are running and how you are liking them? thanks.
Information from Hot Bodies,
Blue compound Rover tires are in stock and White compound Rover tires will be in stock next week at Hot Bodies
Thanks
Thanks Kaz
. I normally order from my favorite LHS, and he orders from Horizon Hobby. The eta on my order just said December. I suppose with the info you just gave us, that eta won't be too far off:-P. I can't wait to get them!!!!!
How are they in sidehilling. I am running the Carvers and they perform very well on sidehilling. I ordered medium Rovers from RPP so will see how they work.:)
just picked up a set of these from the lhs. Cant wait to try em out. running star cut axial foams. Not sure on what compound tho. They do have a blue dot on them.
No need to star cut the axial foams they are soft enough. Actually I wouldn't cut them at all & if you have already cut them, just use the stock HB foams. The stock foams are pretty much identical to the Axial foams.
Mine have a white dot. I think mine are the soft compound.
Blue compound = Firm - A blue dot on the sidewall
White compound = Soft - A white dot on the sidewall
We use the same color code that used Hot Bodies Buggy tires.
well these tires kick a$$. They performed great. Dont see myself making any changes. May just try the stock foams once but the star cut foams work great.
Mounted a set up on HPI's new beadlock wheels. The size differance is very noticable. And they mounted up nice on the wheels. Ready to try out.
