toy4crawlin
My goal is to run a single servo off 2 different channels. I want to use my channel 3 (push button by my thumb) to get into my dig and lock the rear wheels. Then use channel 4 to get the dig servo into neutral.
I don't know if the channels are constantly putting out signals or only when they are being used? Maybe Ill need a diode to keep the signals from back feeding? I was just wondering if anyone has tried it or knows if it will work/wont work and what needs to be done.
couldnt you just mod the transmitter channel switch with a toggle switch?
you could do a return center center toggle switch and add resistors to it so it knows to return to center.
if I hear you correctly, you are selecting a ch to tell the servo to do function A, but using another ch to make servo to do function B, so how is A going to allow that while A signal is telling it to stay in that position.
sounds similiar to the traxxas TX3 3rd channel mod. it was a two position switch but we modded it so that pressing 1 button makes server turn clockwise, release button and it return to center, push 2 button and it turns counter clocks wise.
is that what you want? unknown what your locker is.
