Thank You so much for this thread help.
I have searched RCC , google , youtube and castle.
I have Dual Torque master XL's and trying to configure the mixes with my DX6i custom pistol , but I gave up because my Spektrum Elevator POT is faulty and now trying with my bran New 2017 DX6 stick.
on RCC I found instructions on DX6 but that is a very old model and not the same as the new DX6 .
Cant seem to find how to configure a DX6i with dual esc's .
Problems, please help:
1. Finally got my front Torque master BR XL calibrated and functioning on right stick Pitch but could not get the rear ESC Torque master going. After much changes, I got the rear working on my New DX6 but now the front stopped working.
My front ESC calibrates, but the motor beeps ( HH Hand wound Pro 35t brushed.) Guessing that the ESC is misconfigured in the esc, I connected to Castle Link, but did not find anything out of place.
No results on castle, google, RCC. about motor beep after ESC calibration.
2. The closets that I have gotten is reverse on my MOA , but when try forward motion, the front axle and rear axle go in opposite directions. so then I made another mix change and now, left stick operates rear axle forward and reverse but no front motor, when check the TX monitor it shows that they go in same direction, but in reverse the other axle is opposite direction. erghh.
Goal:
Either use my custom DX6i pistol so that the mix/momentary button allows front dig and my Mix 2 (ail DR) switch allows for independent rear drive .
or use my New DX6 stick and right stick Pitch runs front axle, left stick rudder runs rear axle, and Switch H is my mix for Pitch>rudder so that Pitch CH is master for front/rear throttles.
Also, to add ,I have disconnected the negative lead to the rear ESC. but still through Front ESC Calibration the Front motor continues to beep and ESC never Arms.
As I continue to troubleshoot I have run castle update and new firmware
thank you
