You don't, you use multiple smaller batteries.Holy balls!
They have a 400kv 75v / 16s motor!
It's 56mm diameter by 113mm long, wow.
Where do you even get batteries for that thing...
Sent from my Nexus 6 using Tapatalk
John,
Would you tell me the advantages of the Brushless Puller Pro motor vs the Brushless Trailmaster Pro motor. I'm curious as to the price difference & the 2 pole vs 4 pole.
I'm not sure if it will fit in the TRX-4 mounting holes, but RPM makes a mounting cage for the Mamba X. I have it in my bomber, works well and gives you a place to mount the on off switch.
Sent from my Nexus 5 using Tapatalk
Quick question for Holmes Hobbies.
I know this is a crawler site but do you have or ever plan to make a motor that would work in a pure 1/8 basher ?
Maybe something for the Arrma Kraton on 4 to 6s?
I know the Mamba Monster can be used but high end motors are MIA.
Thank you
I'm in process of making a line of 1/8th scale motors right now. They are being tuned primarily for off road racing needs first. Low speed control, tractable acceleration, high efficiency. It will be quite a few months before we get to production however, we need to really wring them out on the track first.
Same, the Kraton is in my future, just need to wait for the right moment [emoji41]Nice, maybe by then I'll have a 1/8 vehicle
I found a guy in an Arrma group on Facebook who sells them at a discount, pm me if you're interested.Same, the Kraton is in my future, just need to wait for the right moment [emoji41]
7.4 is 7.4 ............ smoke knows no high voltage
Hang up and Drive
When a servo says it's rated for 7.4v, does that mean I can run it directly off a 2S lipo? As I understand it, 2S lipos have a nominal voltage of 7.4v, but when fully charged they have an actual voltage of around 8.4v.
I'd say free advertizing and maybe cooling?Another thing I've been curious about is the metal sleeves that sometimes come on sealed cans, are they just there to put a label on or do they serve a purpose?
