Harley's Guide to a Bulletproof Wraith
I am building Harley's bomb proof trans. I purchased the super shafty top shaft, outputs and Robinson racing slipper. The problem I'm having is the pin to hold the slipper on the shaft is larger than stock and will not fit int the slipper. The instructions on the RR slipper say to use the stock pin. Which is smaller than the pin on the SS. My question is do I file out the slot in the back of the RR slipper to accept the larger SS pin or use the weaker stock pin. Thanks for any help or advice.
We made our Pin so that the RR slipper has to "Press Fit" on our shaft
Simply Tighten the nut all the way down after assembled and crank on it
Then back the nut off to desired position
Best Regards rick
Can someone tell me if the Robinson Racing HP Slipper Unit 56T Gen 3 Slash as set out on page 1 works with the stock top shaft?
Does anybody have any thoughts on the Locked Up Slipper Eliminator vs. Super Shafty Beefy Shaft with RR Slash spur?
Is the slipper a good insurance policy?
I see much more info on the SS/RR slipper than the Eliminator so I would have to assume it is a more popular combo.
Well I'm fine with the spur being not as strong. Because thinking about going plastic anyway. That way that's my week link in drive line.
