sic1to
Not specifically yet since we have just been testing them. I did do a video on them but that's about all.
SO HPI bushings still, for now???
S.s. 6mm outputs with the mip 6mm hubs. What do you use to attach the hub to the output. I see the hubs comes with set screws but the output comes with a hole in it like the newer style axial outputs. Thanks Mike.
harley what would ypou choose between gmade xd,proline powerstroke,rc4wd king shocks?
Proline personally. I dont think he has ever ran the piggybacks on this particular rig.
Sorry if this as already been addressed but can you still run the servo on the axle using the vp axle truss ? Or do you have to run a cms kit ?
how would you go about bulletproofing an ax2 transmission?? searched for it and not finding much information at all. access to parts in australia is tough so kind of want to get it right from the start.![]()
hey harley i was wondering if the traxxas hd slipper unit bolts on to the factory wraith trans? mine is mostly stock but with upgraded internal gears. if its not a direct bolt on what mods would i have to make thanks.
Blew out the gears on my HS7954SH steering servo this weekend.:evil: Looking at either the HS7950TH or maybe the BLS172SV. Kinda don't want to spend $220 on a servo but if it's the best then so be it. I am running a VP CMS if that matters. Opinions?
It's unfortunate that the 157 is no longer available. If you can hunt one of those down then it would be worth a shot otherwise for cost reasons I'd have to tell you to buy the Hitec.
Why is futaba still advertising it at the top of the page?
