ATTENTION!
Lords, remove your hats!
Ladies, stand quietly behind your husbands!
All rise for his majesty!
The King of Trails!
Yes peasants, the King has returned to the land of SVT's garage to undergo a minor procedure. The stresses of a King are many and sometimes you just have to get away for a reset. Q and Snake are getting right to work because much like doctors that have to perform surgery on Russian leaders, it is easy to come down with a sudden case of "being horribly murdered" if things don't go as planned with a VIP.
First we tend to the tires.
While the King has not had as many adventures as hoped, I noticed the tires were looking a little off. 3 of the 4 were pretty flat so I figured it had been left sitting on the tires a little too long. Turned out the foams were fine but only 1 of the 4 had been vented so when the cooler temps of the fall kicked in, they turned into perm-flats.
This situation will be blamed solely on the shoddy work of an inexperienced builder who will be punished swiftly and severely. Though as ruler of this domain, I am above the law and a peasant was drawn and quartered in my place. Penance was served and order restored.
I guess an organ transplant isn't really considered a "minor procedure" but we can pretend.
The Holmes SHV500 originally installed was stolen for my Capra. As the King is packing a Mamba X, it didn't need the direct battery powered servo nearly as much so a donation was graciously agreed upon. The new servo is a Xpert AS8601 that I picked up on Black Friday last year. It has all the standard good servo stuff: brushless motor, aluminum case, blah blah. The only real important part is 500 oz of torque at 8V should keep the bearings of the King true.
An important lesson that a wise king must learn is to be self aware and seek improvement. One must never get
over the
drive to be better.
Admit it, you missed this amazingly witty wordplay.
The SSD overdrive gears were something I planned on picking up as soon as I knew they were going to be a thing. Originally, the plan was to install these in my Capra but the mesh in the Capra housings was notchier than an unoiled torture rack.
The locker was installed and things were ready to be bolted in.
A great deal of intellectual laziness is going on right now because these pics were originally taken for my Capra thread. Isn't it fun to peek behind the curtain and see how the sausage is made? Almost as fun as smashing together metaphors.
Installing the OD gears in the King's axles was a night and day difference from the Capra housings. They turn as smooth as the stock gears in this application which much more aligned with my expectations than the initial Capra based impressions.
While installing the gears and servo, there was an area of maintenance concern on the front end even after only a short time of driving. The screws holding the drag link and tie rod on the knuckles had loosened. The passenger side was especially bad after backing off enough the screw was only held on by the upper steering arm. As this seems to happen to many of my trucks, longer screws and locknuts were used to retain the knuckle screws and prevent future loosening.
With that final bit, the King is better than new and ready to embark on adventures anew!
We have reached the point of the thread where I say I'm going to go drive said truck then like 3 months pass and that doesn't happen so we are skipping that part today. I respect your intellect as a reader so you won't be fed the typical BS we both know I don't follow through on anyway. Man, I am the worst.
May you all have a blessed season of corrupted Pagan traditions!
