losikid
Got Worms?
Is there a way to use a plane/heli esc with this remote? I have a gt3-c flashed for my wraith but I just got an air boat which I'm trying to get going.
When I turn it all on it starts at half throttle. I need to go full reverse to stop the blades.
Any help would be great.
yea
Code:
- mixes 4WS, DIG,[COLOR="Red"] throttle brake cut-off (for boats with forward-only
throttle)[/COLOR], Multi-Position (to set arbitrary up to 8 positions),
brake channel (to send brake side of throttle to extra channel)
[COLOR="red"]> choose menu EPOINT and press ENTER-long
> menu EPOINT will blink[/COLOR]
[COLOR="red"] > select[/COLOR] one of mixes 4WS (4), DIG (d), [COLOR="red"]brake cut-off (b),[/COLOR]
multi-position (P), brake channel (8)
for mixes 4WS, DIG:
> press ENTER and choose channel for this mix or OFF
- for dual-ESC steering (boat, tank, ...) select DIG channel 1 and
with steering D/R reduce required ESC travel (at 100% it will go to
contra to allow steering at place)
> press ENTER and set mix in range -100...0...100 %
0% is default and means both channels have same max steering/throttle
100% means 100% reduce on rear steering/throttle (eg. no steering)
-100% means 100% reduce on front steering/throttle (eg. no steering)
> for 4WS press ENTER and select crab (CR1) or no-crab (CR0)
for Multi-Position:
> there are 4 Multi-Positions identified by numbers 1..4, they have
8/6/4/4 positions
> press ENTER and choose channel for this function or OFF
- channel can be "D" also, which means map to DIG function
> press ENTER and set channel value for first position
> press ENTER and set channel value for second position or END
> ... up to eight position
[COLOR="red"] for brake cut-off:
> press ENTER and choose OFF or CUT[/COLOR]
for brake channel:
> press ENTER and choose channel fro brake or OFF
