Someone is my group is using a FusionPro Mini16 in a 1/10 crawler that's little over 6lbs and it seemed to perform just as good as it's full size counter part.
Thinking this might be a good option for someone wanting to reduce weight as i think it's 178grams lighter. I might want to try this setup in one of my MST CFX rigs as the motor sits up a little high in this rig and reducing that much weight up high would really help it out I think.
Anyone else have experience with running this? Wonder what the weight limit would be before overheating...
He said you need the hobbywing adapter plate and 2.3mm pinion or a brass sleeve to increase the motor shaft dia to use standard 3.17mm pinions.
