mikemcE
I actually used a SW3 I had for another truck, didn't cog at all, had a good drag brake , but it was big and ugly
Hang up and Drive
Hang up and Drive
Seriously? Cogging is normal with one esc? No. This isn't a sensorless brushless setup. Lol
OP, stock esc is a joke. Yes it cogs and doesn't have a low voltage cut off either. Ditch the esc/dig switch, shocks and servo ASAP! Holmes dual esc and big bores or scx shocks. Servo, anything with at least 500oz. "thumbsup"
But for the time being, you can swap out the esc and run a different one with the dig switch. I had an axial ae5 laying around so I put that in. Waaay better. But that's gone now and running a holmes setup.
Don't blame me for your esc problems....
84yoda is right it's probably more of motor stall not cogging. My assumption was Evo was calling motor stall Cogging.
Did all motor stall (cogging) go away with the ae5 esc?
Motor stall is normal with single esc...
I didn't use the bec off stock esc. I went with a castle bec since it can push more amps.
I think the tmaxx use the tra2662 (4")? If so, those are 'big bores'. While those will work, personally I would limit them since there longer then stock. Stock up front is 4" long but you will probably need to reuse the bent rod end to clear the servo and that will make those 2662 shocks way to long. Stock rear is 3.5". So those 2662 are already to long. But again, they will work and perform better then stock for sure. Just a tad to long to get the best performance.
I found some heat shrink at my lhs but amain or ebay have plenty to choose from. I asked John at HH about his heat shrink and he said to email them and request it and they will add it to there site. But that will probably take some time.
Yeah I'm not trying to spend anymore right now
The AE5 esc should work much better and I recommend doing that if you already have one, its got lipo cutoff that the stock esc does not. Be aware if you go to dual esc's you'll also need a better 4 channel radio to control them. Im in the process of finally upgrading the "loaner" and will be going to a Tekin FXR and Castle BEC, I already have them from other projects. Also the shocks are getting swapped out for some SCX10 Icons. The rigs been beat on for a season and haven't had any real issues with it, cogging is almost not noticeable but I've heard of others that have been pretty bad. The esc swap should fix that. Also this is a comp rig, so the biggest battery I would recommend is an 850 size.
I had the spektrum dx4c at one time, it'll do what you need but I found it way more complicated than the Futaba 4pl or Airtronics MT4.
I used a stock plastic pivot ball from axial kits to limit my scx10 shocks internally. (Maybe 7mm)
Made this video for you...... Watch it in fast forward video got really long... Pick up rcbro springs and springs cups you'll be ready to go.. IMO
REMEMBER FAST FORWARD.....
