So I believe the inner bearing is normally 5mm on the knuckle. The outer one is 3.5mm. So now the outer bearing hangs out .5mm and the inner bearing sits in a full millimeter. Because they are both 4mm now. That explains the difference in length between axial and b2 shafts.
Also. I have xr/wraith 8* knuckle and chubs on my scx10 how would the 8* help? And I can do some testing before you buy anything if you want robbob. I don't know what brand they are though.
And yes those are the bearings. Took one of each, on each side.
