cykb4117
General Vehicle Details:
• Vehicles must resemble 1:1. Event Officials have full discretion to determine if a vehicle is accepted and how scale points are scored.
• No TVP (twin vertical plate) chassis' or frame rail extensions on a TVPs. Tub chassis are allowed, but chassis must be covered by the body and follow all other scale rules per class guidelines. An example of a tub chassis vehicle is CC-01, DF01, Twin Hammers, etc.
• Multi axle vehicles allowed in all classes.
• Rear steering(RS) or dig is allowed in modified class only, C3.
• No "Motor On Axle" (MOA) of any kind. All motors, transmissions, and other electronics (other than steering servos) must be chassis or frame mounted. Your axles must be driven by one transmission or transfer case and a minimum of two drive shafts (except CC-01, TA-02, etc) No separate throttle control of drive shafts or axles.
• Wheels larger than 2.2 are not allowed in any class and no short course style wheels with split diameters.
• Wheels must resemble a 1:1 type wheel. Wheels with exposed foams or front side stand off construction are not legal in any class. Fibre Reinforced Plastic (Ex: Carbon Fiber), translucent and clear materials are not acceptable.
• No bolt on or stick on external axle or knuckle weights of any kind.
• Any functional recovery tools you wish to use during your run, you must carry it on your rig at all times. IE tow strap, pull pal, and sand ladders.
• Winching can only be performed off of a natural object. Winching off of a person shoe is allowed as long as the shoe doesn't move.
• All vehicles should have the motor, transmission, and electronics covered and hidden when viewed from the top and sides. Batteries must be chassis mounted and should be hidden from view.
• Water proofing is HIGHLY recommended!!!!! Expect your rig to get wet!
Tires:
Tires should be scale appearing, if it is questionable have it reviewed before the event, or plan to run a different tire. As new competition specific tires are released the ban list may be updated. Tire size will be determined by advertised manufacturer specs (tires without available specs will be measured off the truck as mounted on the wheel laid flat).
Tire Modification:
• Class-1 Street: No external tire modification is allowed.
• Class-2 Trail: Tire lugs may be removed, siped, grooved and/or trimmed.
Class-2.5: Same as class 2
• Class-3 Modified: Tire modifications are permitted, as long as the tire is no larger than 5.75" in diameter measured off the vehicle laying on its side, and all tire parts are from a legal scale tire.
Tire Ban List:
• Losi Claws, Boss Claws and bashers
• Hot Bodies Rovers and Sedonas
• HPI Rock Grabbers
• Panther Cougars and Leopards
• Pro-Line Chisels
• RC4WD X-Locks, Crazy Crawlers and Rocklin
• Imex Skulls and Bones
• Ottsix Voodoo PINS
• JConcepts Ruptures
Tires:
Tire Modification:
Tire Ban List:
• HPI Rock Grabbers
• Pro-Line Chisels
