motoxkfx
Ok i have a wraith with a venom 3300 kv brushless motor and esc. I have bin running it on a 2s pack with no problems but i wanted more power so i went to 3s and that is when the problems started.i ran it on the 3s for about 5 min and it ate the idler gear so i went and got new steel gears. the hobby shop did not have them for the wraith so i got the ones for the ax-10 and took them home. once i got home i realized the out put shafts where not the same so i took the transmission out of my ax-10 and used it every thing works great but the rear drive shaft is not long enough now. there is only about 5 or 6 mm that is actually connected and when i put it on the ground and nail it the drive shaft pops apart. what can i use that has a longer drive shaft.
