losikid
Got Worms?
OverkillRC has your back!
OverkillRC has Cutters, Crimpers, and Strippers to turn your rats nest into a clean and tidy wiring harness.
First up is the flush cutters. Flush cutters are basically a different form of the typical diagonal cutter. The major difference is that they are ground flush on the back side. This is for cutting off soldered leads flush to a circuit board. However, this also creates a nice sharp edge for improved wire cutting performance.
CLICK HERE FOR PRICE AND FULL DESCRIPTION
Next up is the wire strippers. I'll offer two sizes
10-22AWG which will be great for battery and power wires. I've also used them in automotive and residential wiring.
CLICK HERE FOR THE 10-22 AWG STRIPPERS
And then, there is the 20-30 AWG strippers. These are great for servo wires.
CLICK HERE FOR THE 20-30 AWG STRIPPERS
We also now have a professional crimping tool for all your servo connector needs
Servo Plug Crimpers
It comes with a single stage die, so get a solid crimp around the insulation and wire stands with one squeeze!
It also has a ratcheting mechanism which provides a better mechanical advantage (leverage). This allows for tighter, more consistent crimps and it's easier to use.
Professional, tight crimps that you can rely on
How to make a Crimp in 5 Steps
We also sell female terminals and housings so you can shorten all those pesky servo leads
Servo Plugs
Post up any feedback or suggestions on what else you'd like to see OverkillRC carry. Thanks!
Servo Plug Crimpers
Servo Plugs
