Custom 6x6 Heavy Truck
wolfsbone01
Subscribed Member
Tijeras
Hello, Everyone; I thought I'd share my current build: a custom-designed 6x6 Heavy Truck set up as a tow truck. The chassis is of my design, along with the body. The axles are TRX-4/6, sitting on leaf springs. Yes, I know that portals and leaf springs are a recipe for disaster, but we will see how things go. It will run a Lesu 3spd transmission paired with a Holmes Hobby 1800kV revolver. Steering will be SOA with a Tekin T-440. The truck cab will be 3D printed once I'm done with designing. There will be a number of chassis braces that I will machine out of Delrin and/or aluminum. The tow boom rendering is just a mock-up for now, as I'm unsure where to place it.
Neat build. Who's the helping paw? Tell it I said psssss, pssssss. Cute 😍
add a link in the upper mount on each axle to control axle wrap
those leaf springs like to bend and break and with portals theres alot of leverage on those poor things lol
the trick is to mount the upper link to the chassis so theres no binding and you still get full range of traval
Running spring under i think you've given the leaf springs a fighting chance.
Bgredjeep, I'm hoping that as well. I've got TRX-4 axles under my BRX01, with the rear leaf sprung, and anti-wrap bars, and so far, so good.
Gula, the helping paw is Trixie; she's never far from me.
ferp420, I have anti-wraps on the mid and rear axles. I'm currently trying to figure out how to setup the front axle.
Thanks everyone for the feedback. Here are some updates. The chassis is about 8mm thick, which is thicker than the Trailfinder chassis and the Boomracing BRX01 chassis, but it allows me to mount the none pivot leaf mount solid where there is enough play to help with suspension flex. As of now, I have the transmission and shift servo mounted. Unfortunately, now that my grad school classes begin Monday, I won't have as much free time to work on this.
Well, a major update: the body is here, but I am not all that happy with the quality of the print. I hoped to paint the body as is, but that won't happen now, as I need to do more sanding and filling/crack repair. The body and all of its pieces are printed ABS at a 100% fill rate. You can tell on the cab there was a slight shift during print, which is where the cracks are. Thankfully, I'll have a little downtime between grad classes, so I can work on this.
M-916 Wulver 0021rs.jpgM-916 Wulver 0022rs.jpgM-916 Wulver 0023rs.jpgM-916 Wulver 0024rs.jpgM-916 Wulver 0025rs.jpgM-916 Wulver 0026rs.jpgM-916 Wulver 0027rs.jpgM-916 Wulver 0028rs.jpgM-916 Wulver 0029rs.jpgM-916 Wulver 0031rs.jpg
Well, the paint is done, but I still have decals that I'm working on. So, the body is not quite finished. However, I'm hoping by tonight, I'll have it all put together, minus the windows and decals, as I need to finish them. When the boom is at its full extension, it is about 16" tall.
p.s. I hate wiring.
M-916 Wulver 0051rs.jpgM-916 Wulver 0052rs.jpgM-916 Wulver 0053rs.jpgM-916 Wulver 0054rs.jpg
Well, she has had her first shakedown run, and I couldn't be happier. She performed better than I had expected. There are still a few things that I need to wrap up. However, I need to tinker with the shift servo and linkage for the transmission, as it only wanted to work in low gear, and the other two were slipping or not engaging. Also handled pulling a rig on the hook and sling very well. I may have to make a new sling bar with more depth to cradle the front bumper better. The rear winch worked well, but it was slow, so I may need to design a free spool version. The nice thing is that I know I'll never use all of the line spooled as it's close to 30 feetM-916 Wulver 0056rs.jpgM-916 Wulver 0057rs.jpgM-916 Wulver 0059rs.jpgM-916 Wulver 0060rs.jpgM-916 Wulver 0061rs.jpgM-916 Wulver 0062rs.jpg.
