FlightInstrukta
Master Rocksmith...
Not sure if this is the right place on the forum for this rig, but i just wanted to show off my 2.2 custom tuber a lil bit...
It's a one of a kind handmade frame on built SCX10 axles with RC4WD R2 trans and a Holmes Hobbies 1100 kv revolver outrunner motor, powered my a mamba max and cc bec, and a spektrum dsm2 3100 w/ dx3r... xr10 wheels(narrowed to 1") with axial ripsaw tires...
the wheelbase is a lil long, so imma try n get the front links about a 1/4" shorter, and it really suffers from high COG, with all of that solid steel rod, so imma try a half droop setup on the shocks... speaking of shocks, i left those out in the above paragraph... i was pretty proud of myself when i came up with those, the shock bodys are from the front of a nitro associated sc8, and the springs are the single stage proline powerstroke spring from the scaler shock kit, still waitin on the jeepindoug cups, and then have to modify em to fit the huge associated end rod... fun fun...
lastly, is really needs new wheels, got a set of VP DHI revolvers comin with a bunch of different hubs, so imma widen it up a bit to try n keep it planted on the rocks... if i dont achieve the setup im after, ill probably tear it down and make a FOFF truck out of it, its solid steel, so its practically bulletproof, would probably be a good platform to start with?
