Alpha Male
New tires came today, too. These are RC4WD Falken Wildpeak. They are the tallest 1.9 I could find at 4.82 inches around and I like the tall tires look on this body and frame.
Really nice!
You're tempting me, damn...
Is it the exaust system empty inside?
I'd like to put a smoke system in it...
Please make a video as soon as you can...
Did the ch3 winch setup work without issues? What winch controller are you using?:mrgreen: Goof.
I set all of the electronics out on the counter and started trying to figure out how to use this new transmitter. Took about an hour to get it all working correctly and solder everything together. Drag brake still needs to be dialed back, lol.
Anyway, this is a Radiolink RC3S - 2.4ghz, 4 channels and cheap! It cost me $34 shipped. I don't buy expensive radio equipment because I insist on having a separate transmitter for each truck, so other people can drive my stuff with me.
Channel 1 is obviously for steering, but it is also split with a Y harness so that a second servo can turn the steering wheel inside the truck.
Channel 2 is only throttle and brake, but the sound unit and smoker (hopefully) will run proportionally with the throttle.
Channel 3 is a knob that is used with a wired winch controller for forward, backward and center, without a wireless key fob.
Channel 4 is a push button that will switch the transmission between high and low gear, as long as the low profile servo fits (hasn't arrived yet).
https://www.youtube.com/watch?v=PMroU2L3BCs&feature=youtu.be
What's wrong with tbe Essone sound unit? I set one up for a mate and when trying to programit on the computer or update the firmware it kept failing. I had to adjust the communication rate in the settings before it worked.The exhaust is made of two parts glued together, but they are empty inside, like a straw. I'm going to use a smoke unit too, but I'm working out some other problems right now.
My servo controller burned up, my sound unit isn't working, the steering wheel servo is not quite right yet and I'm still waiting for my front wheels, which have been setting in U.S. customs for two weeks.
After all that is fixed I'll make a video. :mrgreen:
Cool looking truck for sure. I have seen the Cross RC trucks but only delivered from China. Is that where this shipped from? If so, how long did it take to arrive?
Ive built a GC4 from Cross Rc, the manual wasnt very detailed, and in some spots the wrong piece of the tray was used as they dont show the finer details. But it turned out alright in the end, you wouldnt be able to noticeAre these difficult to build? I'm on a group in fb and some of the members say they are quite difficult.
Sup Jake? When are we going to take yours out? Mt dandenong or ringwood bypass sunday afternoon?Ive built a GC4 from Cross Rc, the manual wasnt very detailed, and in some spots the wrong piece of the tray was used as they dont show the finer details. But it turned out alright in the end, you wouldnt be able to notice
Sent from my SM-G930F using Tapatalk
Havent been to Ringwood so would be keen! Im busy this weekend, i can do the friday before the long weekend though?Sup Jake? When are we going to take yours out? Mt dandenong or ringwood bypass sunday afternoon?
