Clod Wiring Diagram
NickRummy
Akron
Well since I'm building a clod I have been researching a lot about motor/servo/battery/esc wiring. It seems the same question is asked over and over again about series and parallel wiring and motor reversing. I thought I would draw up a diagram for everyone to use. This is how I'm going to wire mine using Deans plugs so the motors and ESC are removeable. If anyone sees something that should be added or removed let me know. If there are other diagrams I can draw to help out I'd be happy to do them.
The motors in this Diagram are set to 0 degrees timing.
Click to enlarge.
Nice job. What if you use a receiver pack though. You should draw one for each.
Well i have never used a receiver pack so....... I'm assuming it would go in that left over slot on the receiver?
So corey,
B - receiver batter
1 - ESC
2 - front servo
3 - rear servo (optional)
Correct?
Sure.
I can't edit that diagram until i get into work tomorrow.
I'll have to do some research on how to set up the dual esc setup. When i figure it out i'll post it up.
Updated the wiring diagram. Just click to enlarge.
Oneleggedmachinest, do you have a larger image? It's hard to pick out whats what on that diagram. I think I'm following you though. :)
give me a little while ill repost bigger the owner of hooby store i go to says this will last the longest and most even power to both motorshttp://hobbyetc.com/ in nashua newhampshire
he said don't waist your money on big$ esc's all you need is two 15t-20t esc
one traxxas y harness,two servos ,two motors,two battery packs "one sucks",and reciever 3ch
tried new draigram but photobucket shinks it alittle so you may have to save and blow up on your own or ill email it direct to you.
two novak goat systems
how do i set up two novak goat brushless systems on my super class clod? im only running one servo and im using an airtronics mx-3 radio with two max amps li-po's but im not quite sure about how to wire two speed controls to one reciever. will it deliver too much juice to put a y connecter??
