Hoosierdady
Fan of wheelspeed
Im working on a TTC rig and thought Id share how I made a custom hood scoop, filled the sunroof and made a cab back for it.
I cut the body carefully to seperate it from the bed.
I cut a rectangular piece of styrene and two angled pieces for the sides and glued them together.
The cab back was easy. Once the cut was cleaned up on the cab, I just layed it on the styrene and traced the body, and cut out two of them. Then I cut some squares out of one of the pieces to make a contoured back.
Some Tenax77, Shoogoo and Gorilla CA glue to hold everything in place. Once all of that dried, I sanded it down, applied some glazing putty and let it dry.
Then I cut a thin strip of styrene out for the rib down the hood, and started sanding.
