Some set back today....again
I was putting the motors on and inspecting the gears....front axle has a little click and jog every revolution at the same spot....not near as noticeable when the motor is engaged....also noticed the chub screw was twisted off. Not such a big deal unless I need to get inside
Not a show stopper by itself, but the rear axle, although being smooth without a motor, will not turn over with a motor attached. Makes about a small turn then stops dead...in both directions. Not sure what to make of it.
It's what I get for buying used I guess...
I have back up axles on the Mantis I'll use....no more frustration ....damit :mrgreen:
I did get the shocks squared away....88mm eye to eye BigBore, losi mini t front springs, pink(soft) and 40 wt all around. Really wanted to mock it up again but the axles changed all that.
Cheers
