Imprez
Cool, thanks guys, your answers are much appreciated !!!
GEARING!
Are you running something for mostly trails and crawling (example, 35t Torqemaster)? Short Story, 84/18
If you changed out your motor to something with a little more low end control and power then you likely could benefit from a better gear ratio. This isn't a must for a setup in this range however. The stock ratio is OK, but just not ideal in my opinion for someone who is looking to spend most of their time going slow. I do still feel that even if you're a rock crawler only that you will benefit from some wheel speed. I would suggest that if you do change gearing you start with an 84/18 setup.
Harley for the life of my i cant find a 84t spur in a 32p >.<. i've already picked up the 18t 32p pinion just trying to find that spur lol.
Thanks. Any online site you prefer..three local shops are all traxxas stuff
sent using a string and an empty beer can
I think I've decided on a Holmes hobbies torque master pro rock racer combo 27T for my wraith kit. With their brxl. Can that combo run on 3s? Or should I run on 2s? I got a futaba 4pl controller. And should I install a BEC? I'd like to keep the stock gears and not change those. Mainly a trail rig with some crawling here and there.![]()
Alright thanks Harley. If I were to run the stock gearing for now what would the issues be? To much speed for crawling? Would I just need to be careful while crawling and not get it in a bind? Thanks again.
I'm a little confused on what gear ratio now your first post said 56/16 and I've also been told by others a 86/16. So which is right? Those see to opposite ends of the spectrum so to speak
