Harley...
Ok thank you! What if I went with a 32P 56t spur and a 13T pinion?
Great thread.........only WAY to long! LOL
I am running 32P 60/10 spur/pinion with the 27T Axial motor and want to upgrade the motor (I think.....) I am doing mainly crawling with some trail driving. So far I am liking the power/speed from this setup on a 2S. It is a bit slower than I want and am thinking about going to a 11 or 12 pinion when a bit more wheel speed is wanted.
If I decide to upgrade the ECS/motor, which would be better ..... Holmes Hobby CrawlMaster Pro 13T w/ BRXL or Timbuk2 Wraith edition? I am not planning on a lot of water/mud driving but want to be sure that I could get it a bit wet when needed.
If I put a 55t motor in my wraith with stock gearing would it be similar to a honcho with a 35t motor with stock gearing thanks
i havent read through this entire thread. its SUPER long!
wanting a suggestion though.
ill mainly be crawling, but want enough wheel speed for trails and climbing dirt hills. i saw you recommended the 13t crawlmaster, but how good will the 13t crawl? should i go 16?
also, would you recommend 2s or 3s if it were yours? will also be using a cc bec for servo
I read the first page, I was just a little unclear I guess.
Were the results in first page on 2s, 3s or what?
Is the 13t on 3s enough to crawl really slow but still have the power to get some decent speed as well?
I'm wanting to be able to crawl pretty well because that'll probably be what I'll do the most. I'm just torn between 13 and 16 because I have not used either
He's into crawling, so I suggested one of these, based on your posts on the first page:
TorqueMaster Crawlmaster combo: Holmes Hobbies / Holmes Bikes :: Combos :: TorqueMaster Crawlmaster combo
TorqueMaster Expert combo: Holmes Hobbies / Holmes Bikes :: Combos :: TorqueMaster Expert combo
Do my suggestions come with adequate ESC's?
I have been gathering different gears so that we can play around with our options, so we'll figure that part out 2nd.
Thanks for any help you can give!
I'll pass on the info. Thanks for such a quick reply!
Wonder if that ESC would work with this motor whenever it finally comes out... Holmes Hobbies / Holmes Bikes :: Motors :: Brushed :: Puller 540 Crawler TTC motor
Not enough info to really be able to tell.
