im running the timbuck 2 and want to change to something better not real happy, want more speed able to use 3s packs and be a good crawler NO cogging went there alread just get more confused the more i read. please make my desisision for me!!!!!!!!!!!!!!!!!!
motors with 5mm shafts....
The question is this...
I have a Castle Creations Max Race Pro SCT 25.2V 3800kV System
I found that Robinson Racing Hard 48P Machined 17T Pinion 5m/m Bore
is the smallest pinion that is made to work on a 48p system....
Otherwise it will be needed to converted to 32p ???? Could someone explain this? oR is it already 32p gears??
This uses a 5mm shaft (like the pro4) and if guys are using that then I know I could use this one as well...
Could some one provide part #'s or should I ask in a dif/ post?
I have other options from a older AE sphere brushless/brushed and have a Epic brushed stocker....for 1/10 stadium trucks...
I have all the lathes and all the other junk that goes with the brushed motors...so isn't a issue...but This will be going
into my sons truck...He is 7yrs old...The XR-10 is too much of a serious crawler for him....
And you can't start piecemealing electronics together, and expect it to work properly...EX...dif. turn motors and dif. brand speed controllers and dif. bats...
My brushes need to be replaced, I'm just wondering how long should set of brushes last on a HH 13T on 3s with a 54/14 ratio. I do crawling but also do speed runs I probabily have about 2 hrs of total run time.
I don't know how long I had on my last set, but it was longer then 2 hours. I am guessing I have 6-8 hours on each set.
What would you suggest for a brushed motor if I want to change out the motor for fast runs only. I 'm running a BRXL.
Thanks
I currently have a Tekin RS with the latest firmware update with a 13.5 Redline running on 3s that I pulled from my shortcourse truck. I really like the speed and slow crawling ability but would like the drag brake to hold on decents. I have it turned all the way up but it acts more like a decent control as it still rolls slowly on decents regardless of forward and reverse, it will hold if I give it a little brake or trim it on the transmitter when I need it to hold. My question is, does the Mamba Max Pro hold any better than the Tekin RS or is this just the way it is? I'll switch ESC's if it's better, if not I'll just live with it.
Thanks
MMP has a "Crawler Brake" setting or can be manually set up to 213% drag brake. Simple answer is YES, the MMP has Hella drag brake.
I'm running a Tekin SCX4 550 2pole 4000kv and my Wraith weighs 8+ lbs and the drag brake set at 150% and it keeps it locked up on decent.
