Cbe rc fab yeti-x
Just curious, with the:
STAGE 4:
YETI-X RTR (complete)
You are starting out with the Yeti RTR version and not the kit version, correct? If someone purchases this, will they receive all the stock parts as well? Thx for your time,
STAGE 4:
Yes it will start with the RTR version. And if requested yes the additional parts will come with it.
Sent from my SAMSUNG-SM-N900A using Tapatalk
How much weight does this conversion add?
You mentioned..."We used upgraded steering links from Carter Fab & Machine"...does that mean those will NOT come with Stage 3?
If not, can we pay extra to have those and other traxxas upgrades included?
For weight I am not sure how much it adds but mine weights around 9lbs. And I am sure something could be worked out with the links. "thumbsup"
What if ones yeti has the Vanquish centered currie axle and wanted this slash front end setup on there yeti, can the slash 4x4 front diff be flipped to make the tires go in the same direction? Because the Currie axle has the diff on the opposite side of the housing compared to the stock AR60 housing.. The currie diff can not be flipped thou like the AR60 diff can be. Thanks for any light shed on this.
Yes you can run the centered Currie. Will need to flip the Slash diff and run these bearings from Boca
After switching out the drive pins in the transfer case will mip drive shafts fit? I would like to know because I already have mip shafts installed on my yeti.
Thank you.
