OpisOpus
I can’t give you pics but its fairly straightforward. You pull the trans and separate the halves. The center diff lives in there and has a gear with 4 small phillips screws holding it to the carrier. Pull that off and inside is a set of spider gears. Yank those out and you will see that the “+” shaped locker you bought should just slide right in. The carrier is already slotted to fit it. Then just reassemble.
Ok so got this far. Just don’t know how to get the last part of the gear out of there
