Haven't really had the time, or a reason, lately to come on the forum lately so I decided to give myself a reason. Mostly it's been because Im working a lot more now than I was, and because I've been working on non crawler stuff lately. I picked up a new tlr scte 3.0 and a used rc8b3e.
So this thread will document the rebuild for the b3e. If you have questions about the scte, just let me know. Anyways here's the rc8b3e and the scte
It came as a roller with the v2 diffs already installed, carbon fiber shock towers and upgraded shocks. Also had a set of aka wheels with aka catapult tires in soft compound. It also has rivkins set up on it and is supposed to be very good at the local track, not that I will race it often.
So far I haven't done much to it, just picked up and mounted a jconcepts striker body that's for the nitro version, a set of jconcepts bullet wheels which will get street tires mounted to them and a 3racing servo horn. I have for the most part completely tore it apart.
This was 1 race old and already has some seized bearings and bent driveshafts, so all of the bearings will be replaced and mugen mbx7 and mbx7r driveshafts will go on this (its mostly a direct copy of the mbx7 and mbx7r). Also the bottom of the chassis is scratched up VERY bad and the motor mount won't come off easily so both of those will be replaced and I'll get a chassis protector as well.
The only reassembly I've done is clean the little bit of dirt off the servo/rx mount and installed an airtronics rx-461 (will be using a mt4), also installed a hobby people pro bl-320 brushless digital servo with the 3racing horn.
