This project was started in February 2011. At least that's when the axles were paid for, upfront, in full. The axles arrived to CI in February 2012. Over the next few months I collected needed parts for the build. There were several times where I thought my schedule would clear so I could build this, only to have something else urgent pop up. Finally it's done. At least my part of it anyways. It still needs skinz.
Axles:
SDS Customz Alumi-Fighter Axle Set w/ all the good stuff, 300M CVD's & 300M Straight axle shafts
custom 10Tooth metric berg pinions
Vanquish Products, 8*, Zero Ack, High Clearance Steering Knuckles
Stock Berg gears
Traxxas bearings
SDS 300M 3rd gears
Motors:
Holmes Hobbies 40T custom hand wounds x 2
ESC:
Tekin FXR x2
C.I. HD 4S Cap x 1
Electronics:
WAS Mix unit by OverKill RC
Castle Creation BEC - wired directly to servo
Hitec 7955 - programmed
Sky Lipo 40C, 800MAH, 3S
Chassis & links:
Rock Logics Carbon Fiber Custom Chassis with titanium upper and lower links that are designed specifically for these axles.
Traxxas Revo rod ends
Shocks:
3.5" customized shocks - Traxxas #2660
Because of the lighter weight of this truck all four shocks use traxxas 3 hole pistons.
15w oil in front / Pink springs
25 weight oil in rear / Red springs
Jeepindoug Machined Mini T delrin 2.2 spring cups
Losi Mini T Front Spring set - LOSB1117
The shock caps have been modified to accept Traxxas #2742X Short rod ends
Wheels, Tires, & Foams:
Front - Vanquish Products DH1, 4 ounces total weight (3 VP, 3 CI); HB Rovers, CI Double Deuce Foams
Rear - Vanquish Products SLW V4 1" width, HB Rovers, CI Double Deuce Foams
The day they arrived:
And several more months of tracking down parts and planning a time to actually build it.
Finally it starts:
I started by building the shocks first:
The chassis arrived assembled, the links only needed rod ends attached;
Front Links below (the SDS custom lockers are also pictured);
Rear Links;
Awesome 40T Holmes Motors;
Vanquish Products Items:
Axles:
Stock Berg gears
Traxxas bearings
SDS 300M 3rd gears
Motors:
ESC:
Tekin FXR x2
C.I. HD 4S Cap x 1
Electronics:
Chassis & links:
Shocks:
Finally it starts:
Rear Links;
