saddlesore
So i finally got the body painted and mounted. I swear that took longer than building the chassis. My goal was to paint it hydro blue like the 1:1 version but it came out quite a bit darker than what i wanted. kinda bummed but i can live with it.
here is the list of optional parts i have on the rig:
Knight Customs Angry Eye grill set
Axial JK Unlimited Body with roof
Axial LED light bucket set (for the Angry Eye grill)
SSD 1.9 Assassins
Vanquish SLW 350 hubs (got the track width a bit wider and more scale looking)
SSD Rock Sheild front bumper
RC4WD Atturo Trail Blade (which looks like a knock off of the Toyo Open Country MTs)
RC4WD Mini Warn winch
Axial Poison Spyder JK RockBrawler rear bumper
I was able to squeeze in a 4068 2650kv sensored motor in the thing and im running a 16t pinion.
I'd like to get different headlight lenses. I've seen ones out there that are clear with halo LEDs. Anyone know what brand/parts they are?
The grill/front of the body also has a big gap between it and the front bumper. In fact, i had to grind out a notch in the Angry Eye radiator as well as my battery holder to mount the body. its almost like the frame rails in the front stick out further than the SCX10 because moving the body forward and re-drilling the body post holes would get it closer to the bumper but then the tires end up rubbing on the crusher flares. was the SCX10s wheelbase setup further up the frame rails?
i have a set of Knight Customs inner fenders ordered as well as the Vanquish Brawler Rocker kit to finish off the look. I might eventually wire it up with some LED headlights and a light bar.
i have that winch installed but have no idea how to get it to work.
oh...one last thing. i wanted to bolt/glue on some mesh behind the grill. maybe paint it blue to tie the colors in. any suggestions on what i could use for that?
SSD 1.9 Assassins
