BOMBERINOZ
Starting a new Bomber build, just arranging a list that I can edit & go back to if needed, pics & progress to follow shortly
Body & panels
Stock cage & skid plate
Stock RR10 Bomber side panels, roof and hood painted satin black
Suspension & Links
VP sway bar
ST RACING machined aluminum trailing arms, upper & lower links on the way
Axial Icon shocks, custom length via shorter shafts
Steering
HOLMES HOBBIES HV500 servo
VP Servo Mount
VP horn
RC 4WD Aluminum steering link kit
Axles
Stock AR60 housings & axles for now
Axial HD Bevel Gear set 38/13 - front and rear
ST RACING internal diff holders
XTRA SPEED stainless axle tubes
Drivetrain
Stock RR10 Bomber transfer & Yeti high speed gearbox (this may change)
ST RACING billet motor mount (silver)
HD 60T spur gear
13T pinion gear
Stock driveshafts...for now
((( CHANGED TO SMT10 TRANSMISSION VIA mounting plate )))
Holmes Hobbies extended outdrives
Billet Works Designs FOFF motor plate
Wheels and tires
Axial 2.2 Method Beadlock (Wraith Spawn - black) rims
Crawler Innovations Deuces Wild foams - front and rear
Axial 2.2 Ripsaw tyres
Axial BFG KR2 tyres
GPM Wheel hubs 14mm Orange YT014BOR
Electronics
Racerstar 3660 3800KV motor
Racerstar 120A ESC
Hardware and bearings
Stock Axial hardware for the cage etc & mostly stainless screws for the lower section suspension etc
PLAIG bearings
Body & panels
Suspension & Links
VP sway bar
Steering
VP Servo Mount
VP horn
Axles
Drivetrain
HD 60T spur gear
13T pinion gear
Wheels and tires
Axial BFG KR2 tyres
Electronics
Racerstar 120A ESC
PLAIG bearings
