bilinvic
Unlike a B2B, the wheelbase of a B1B can be adjustable, you can use short Twin Hammers trailing arms, longer Wraith length T/As or the even longer Yeti/Bomber T/As.
I don't see why you could not section the B2B plate, bolt in a small joiner plate, drill new holes for the rear brace, and have a choice of wheelbase.
You could but changing TA's is much easier. Anybody can change TA's to change the wheelbase.
Rjohn929....the B2B has independent suspension front and rear, there's no T/As.
What gear ratios are you running (axle and spur)? trying to gauge due to the added weight and design. Not looking to race this but trail and rock bounce when needed.
Spent the full day out with the guys crawling Mt. Work with my B2B today. It's been a while since I have run this fully independent suspension rig out on the rocks. It performed fantastic and it's so much fun to drive. It's extremely capable in the technical crawls, but not my best crawler in my arsenal of rigs though. I love watching each corner acting independently over obstacles.
The Racer's edge diff putty worked great and I'm very glad I had it today as I'm sure it saved the front Vanquish VVD's from snapping in extreme binds. The only issue I had today was two bent Axial rear dog-bone axles. It's a good thing I was carrying spares and in no time I was up and running again. I think that I'm going to get the same open diff gears (as the front) for the rear axle and fill them with the RE diff putty to see if that saves the rear dog-bones from bending and twisting. I'm so happy with the putty's performance that I'm sure it will be great in the rear diff too.
I can say this for sure, I have no doubts in my mind that building this B2B was definitely worth it. "thumbsup"
The racers edge diff lock is really some awesome stuff. Glad to hear its working out for you too. Any video from this last run?
Sounds like a great run.
Was the bent dogbone on the same side both times?
Yes, both bent dogbones were from the passenger side. I'm feeling optimistic that when I convert the rear diff to a semi-open diff with the Racers Edge diff putty that I won't be bending axles so easily.
Have you manually cycled the suspension to see if the dogbone is bottoming out in the cup at full compression, on that side vs the other? Strangely, on my rig, one side seems to bottom out before the other. :???:
