I wasn't going to do a thread on this truck, but I'm sure I'll end up doing some stuff with it worth sharing eventually. I might as well start now instead of playing catchup later.
The plan for this build was pretty basic. I wanted to build it as vanquish intended, keep it simple and light weight, and see how it performs in a local(ish) comp run monthly at Stone Mountain. I'm selling my scx10 pro as a slider so this rig will get its motor, servo, tires, etc.
I'll spare everyone assembly pictures. I picked up an element zuul body for it. I wanted something different, a little narrower than the comp bodies, but not a power wagon.
Fitting the body
Painted and mounted
Here's a look at the chassis. Fusion pro, nsdrc rs700 v2. The only changes I made during assembly was using the -5 shock ends, and a 50t spur. Other than those and minor adjustments to fit the body, it's straight out of the manual.
Fitting the body
Painted and mounted
