HANgOVER Airbrush RC
Well, Here I go. This is kinda uncharted territory for me. I've built many things from this "styrene' like material. i'ts called Palight. Some kind of "foamed PVC" rigid board. I've made battery trays, body mounts, interiors...but never a whole truck. so we'll see how far I get before I chuck it into the ol' wood burner.
I started out doing some (a lot of) research, to find the exact year and model. And I think I found a winner. Not too difficult, but also the correct wheelbase, without having to do any weird adjustments.
So I printed a side profile of the truck, and used a glue stick to "paste" that to the Palight. Then I traced all the lines with a razor blade. I did the profile of the truck as well as the character lines along the bottom.
Then I traced those lines with a pencil (so I could see them) and cut that part out of the piece of Palight. Then I secured the cutout to the first piece with some 2 sided "carpet" tape. ...Back to the band saw...
Quick and dirty way to make both sides at once...Right?
After much sanding, I pried all the pieces apart. After much quality time with my heat gun, I decided to cut some temporary spars so I could see my progress. (and boost my confidence)
ok, there may be hope. Let's tackle that hood.
After a bit more heat gun action, I came up with this.
I wasn't that excited about it, so I started the roof...
Ok. Still needs some "fine tuning" but day one is over. It's really cold outside, and it's getting cold here in the shed....
