55ovalcharlie
After building a series of Land Rovers (I know you guys aren't massive fans of them - but hey, I'm British so got to show some support :laughing: ) it's time to do one of those foreign things.
I happened to have a pair of Brazin Scale LCG steel chassis rails kicking about and a set of the ever so pretty Vanquish Portals - managed to get a cheap Power Wagon body on a facebook group so though why not.
The Portals are just gorgeous - almost too pretty.
Had a few issues with them though such as incorrect hardware being supplied with them and also a couple of the holes not tapped all the way through which was slightly annoying for a relatively pricey product.
The Power Wagon body has been on my to-do list for a while - super nice quality body.
So I quickly mocked up the chassis with some temporary links so see where things needed to go.
should work just fine - won't be running tyres as big as that though
Lots of clearance there!
Plan is for a fair bit of custom tube work - but not as crazy as some of my previous builds.
couple of pics of "The Race Tractor" for inspiration
kind of the look I'm after, but I'll be keeping the front fenders at least.
A couple of evenings work and the following is done - everything has been made out of 4mm outside diameter, 1mm wall, Stainless Steel tubing
Will most likely at some point be adding a bit more bracing to tie the grille into the fender guards for a bit more added strength
And here is the chassis as it stands. The combination of the LCG chassis rails and the higher than normal axle position has meant that I've had to custom bend up a new pan hard bar to be able to get full travel with the 90mm shocks
I've added some more stainless to the front end to tie it all together and give the spot lights a bit of protection
And then had the day off yesterday as it was my birthday so added a stink load of tubing to the rear end too
The jury is out regarding whether to run the bed sides or not - think I prefer it without.
And battery tray sorted
The end result of all this welding and silver soldering is a very crusty looking lump of stainless steel
BUT......
thankfully I have a friend with a car restoration business and he lets me have free use of his vapour blast cabined which does a fabulous job of cleaning these cages up without being overly abrasive, which leaves you with this....
So the next job is to tidy up some of the joints a bit with a belt sander, then paint the main chassis rails as they're mild steel, but then leave all the tube work as raw stainless finish
Really pleased with how this one is turning out.
In between stuff I made up a new scale backdrop - i'm fortunate to have access to a large format printer - found some pictures on google images and a bit of a photoshopping session later I had this which will hopefully lead to some nice pictures from me
Started the paint this saturday too.
chassis rails painted silver (all the tubing left raw stainless finish though)
exterior of body shell painted using a wide variety of different colours I had left over from previous builds.
Started off with painting the exterior of the lean after a quick scuff up with a 3M pad using some silver tamiya PS polycarbonate paint as a base / primer
then proceeded to add various bits of tamiya TS paints - applied in a haphazard way, zero care taken, sprinkled metal filings in the paint etc.. all to make it look like hell ::2thumbs
this leads to this.....
After that dried I added a pile more weathering / rust and mud to make it look even more rubbish.
Did a couple of "washes" to the shell - brown - green - orange
Using a variety of Tamiya Weathering powers and Vallejo pigments & textured paints.
The vallejo rust pigments are just awesome.
The rear bed sides are an optional fitment - personally I prefer it without
All that was left now was to properly make up a new set of links for it out of stainless - so far it had just been mocked up using some adjustable links I use.
And after that build it all back up again to make sure everything fits - and then fit a set of spotlights.
- Chopped off the lexan running boards - these will be replaced with aluminium checker plate
- Made 2 x "sliders" on either side of the skid
- Main Cab Roll Hoop bent up and welded in place
- Stainless fender guards done
- front bumper done
- front Grille done
- Winch mount done
BUT......
