Truck looks great! I’m interested in what do the shock mounts do to help with steering flex.
I read this thread because I noticed times when steering on obstacles my angle was greatly reduced.
I would think the lower panhard bar Mount as well as the upper.
I’m pleased with the sammix front shock mounts. I like the shock mounting options but the panhard bar Mount is great. Same as stock where the bar is captured on both sides but in aluminum.
I saw a video for the Gen8 regarding this issue and it was substantial flex that affected steering.
I also shimmed up my transmission to remove a clicking sound, but I have also recently developed a nice squeak, both drive shafts got blown out and dry lubed, any thoughts on what this could be?
I’m looking at upgraded lower link/shock mounts also at some point.
The squeak is interesting. Almost like something is too tight but definitely sounds rotational.
I would take the body off, truck supported and run it slow. Then do the same thing upside down.
Hopefully you can pinpoint it that way.
Definitely keep us updated. I’m really curious as to what the cause is
I'll be curious as to what you discover on the squeak as well. My son's just developed this today and I can't pin point where it's coming from. He only has about a half dozen runs on the Sport. It was built as a kit so I know all the gears were properly greased.
Something I didn't add, it's only under load
It’s hard to tell from the video. Like BenP said maybe try getting it on the bench and run it. I even flipped my upside down and ran it with the throttle trimmed up and loading the drivetrain to isolate the clicking when I was investigating the click.
What shims did you use and where? You still have endplay on that secondary main shaft?
