Derek Larsen
No updates in 9 months... Did you have a baby?
Sweet build so far!
Awesome build, and some even better info here! Any chance you'd share the HPI part number for a pinion shaft that will work with the HPI HD gears and Axial drive shafts?
BTW, if you do happen to have problems with the outdrives sliding out of the spool/locker it can be remedied with an o-ring or two dropped into the dogbone cups. Try to use the same number of o-rings in the inner and outers and it will keep the outdrives in, as well as keeping the dog bones centered in the cups. Keeps chewed up dogbones/cups to a minimum. Pretty much a required mod on CC01s with lifts/increased droop to keep the shafts from binding, and the outdrives from falling out.
Just saw this build, very creative. Great idea with the ABS cement. Talented builder....will follow this.
So, to make sure I'm understanding correctly, if I use #86329 in the front and #86336 in the rear, I will need to shave the back side of the front ring gear, and use #82020 pinion shaft in the front? The HD WK/rear gear set looks like it includes a pinion shaft that is integral with the pinion similar to an Axial HD gear set, meaning I wouldn't need an additional shaft for the rear. Sorry for the million questions, and thanks a ton for the info!
sell me that body lol im building the same truck and having a hard time finding the bodys
ps nice work
