1900kv is up: MOTOR, 4-POLE SENSORED BRUSHLESS, 1406-1900KV
Thomas Porfert
Tech Support
Castle Creations
Now if only the next FW for the micro had the upper voltage limit turned off...
Thomas Porfert
Tech Support
Castle Creations
Small motors usually use less energy.
The difference in run time between a tekin 1512 sized 1400kv and a tekin 540 1400kv is about 2 hours.
Correct.. no disagreement there.. but also the drag brake strength and also torque of the motor is much less using a small can/rotor
I run mostly 2 pole 540 motors. My favorite is an old trinity d3.5 17.5kv....
Anything above ~60% db will hold the truck from rolling, any higher and it just endos
Do you run 2s, 3s, or 4s? Drag brake and torque go up with higher voltage.
Price looks good, page said low start is "under control" change in these motors, vs the 2650?
JRH said due to racing background these will be poor slow startup ?
Hang up and Drive
Any ideas what is going on here. Monster X w/HH 3500kv Puller Pro. Holmes sensor wire. V2.02, Turnigy 3 cell 60c. GT3C with abs disabled.
https://youtu.be/h1PE2kzJdyA
Are any motor tabs shorted together from a bad solder job?
That looks similar to the horrible cogging I had. Did you upgrade your firmware to the newest on the Castle site?Any ideas what is going on here. Monster X w/HH 3500kv Puller Pro. Holmes sensor wire. V2.02, Turnigy 3 cell 60c. GT3C with abs disabled.
It's probably not the sensor cable, but it's worth checking.Yes it is updated v2.02. I did double check that the Holmes sensor wire is plugged in fully and stopped by the lhs to pick up a castle adapter so I can try one of the many old sensor wires I have.
Mine acted the same way. It was the firmware. But even the new firmware that I tried (the version before the current release) needed to be on the correct settings or it cogged. I forget what that setting was though. It might have been sensored instead of Smart Sense. I forget how Castle does their settings. I'll try to remember to looking into it when I get home.I just need to tear into it. Make sure wires ABC on the motor isn't shorted. To me it is acting like it's un-sensored.
