so you found a link on live rc to actually see numbers?
so say I race with the big guns right? got that part? and I can keep up.. who are you to say im slow? that was my point.
im gonna have to take trumps idea and build a wall here soon if your ignorance persists.
yall should already know the truck is naturally nose heavy. I don't run weight in my fuel cell because I don't need it. im not jumping it like they do at psycho nitro.
I have some 1 mil in my RR right now to try as soon as the arms come back, probably going to 20 mil or some diff lock in it eventually though as I have some on the bench. The BR has taken a backseat for the time being. I just don't have enough hours in the day to mess with all of them. Since the BR is pretty nose heavy I figured the SS might help out an it and keep the CG low. We'll see what happens.
Since my Rock Rey will spend most of its time crawling and trailing I installed a twin hammers locker I had laying around. Took me a few minutes to get the 1 Million out that I had put in my center diff before. Right now my front has 1 million, that might turn out to be too light too.
I went with stainless. I sent him the stockers for reference.
I would have to change shock oil weight to run those, but id bet it would help balance out the trucks for bashers and help put more power to the ground.
In stock now get yours while you can
Ordered."thumbsup"
Nice. What else is coming out?
He can also do 7075 so barely any weight would be added.
So can anyone give me a quick rundown of what I need to remove to pull the front and centre diffs to grease them?
I've done the rear but there is so much crap at the front, I'm not sure if I need to totally disassemble the front end to get at the diff.
Same with the centre diff...it looks like you have to pull the metal spine plate, rollcage, ESC etc etc...
Any info would be helpful as IFS is much more complicated to get at the diff than a solid axle.
delrin links with a weight system. :shock: for those who want more or less weight!
