losikid
Got Worms?
I don't believe mine is hacked but is there a way to confirm? It does seem that it it was hacked and the throttle was not correctly calibrated it could explain my issue.
You should still be able to calibrate your stock radio.
http://www.rccrawler.com/forum/elec...ck-question-answer-thread-15.html#post3213031
If your trigger doesn't create a range of numbers (when "2" is displayed during the calibration procedure) from roughly zero to roughly 1000 then you have a bad throttle potentiometer. Otherwise calibration should fix your issue.
You may also have to reverse the throttle channel.
Also make sure your EPA's and Dual Rate adjustment is turned all the way up so they aren't limiting your throw....and make sure ABS is turned off
