New SSD SCX10 axle housings
I may have to get a set of these. The look of the stock covers was always my favorite but they hang up more than the rock shield covers, these should solve the hang up problem while retaining the stock look.
I have the AR60 versions on my Bomber and they are awesome. "thumbsup"
axle upgrade time!
I measured around 47-48 degrees of max angle on the shafts"thumbsup" I was hoping to do a side by side comparison with Axial CVDs with diameter measurements, but I guess I either loaned out or used my last sets of the Axial CVDs.
The tubes defiantly add strength to an already strong axle housing
Tube and C bolted in place
I did have an issue on one of the two shafts, the bearing wouldn't go on. a quick hit with some 220 grit sand paper and it slide right on.
knuckle and axle shaft installed. everything fit perfect"thumbsup"
steering angle
