Do axial ax60 diff covers work on these?
No, they do not. Buy the SSD brand optional aluminum covers if you want them. "thumbsup"8)
SSD covers are very nice.
Ok thanks I was wondering more for a pass thru axle on a 6x6 seeing the bomber parts tree has a pass Thur diff coverNo, they do not. Buy the SSD brand optional aluminum covers if you want them. "thumbsup"8)
You might be able to make something work with cutting, grind, drill, JB Weld etc.
SSD any plans for this to build 6x6 setup axles?
Love the axles so far with the exception of the lower edge of the pumpkin getting hung up on rocks rather than slide over like the stock Axials do. For right now I'm going to round the edge with a file and use button head screws.
Will there be narrow width/normal scx10 width versions also?
Will wraith, xr10, rr10, c-hub and knuckle assemblies fit those new D60 wide brass tubes? Trying to determine product compatiblities. Are the CV shafts being made to the exact XR10 shaft specs in that they would require wraith style knuckles?
D60 Wide Brass Tubes (XR mod) are out now. We will be releasing new C hubs, knuckles, CVDs and steering links for these.
