XSRCdesign
D60 Wide Brass Tubes (XR mod) are out now. We will be releasing new C hubs, knuckles, CVDs and steering links for these.
D60 Axle Wide Splined Brass Tubes
Yes yes yes yes yes yes!!!
Everything SSD makes works together in harmony. This means tight tolerance components that mount up perfectly and work the same.
X2 great quality and company that asks and listens to what we want! 8)"thumbsup"
Are the knuckles and c-hubs you are working on different from your current wraith offerings? Just curious why new ones are being developed
Sent from my SM-G920V using Tapatalk
It looks like the ssd pro knuckles gives you even more bad Ackerman than the stock scx plastic knuckles. Is this the case? Why did not ssd make zero Ackerman knuckles from the get go?
Can i replace just the front stock axle with ssd d60? I read about reversing direction on these axles. So does that mean i have to buy ssd axles for both the front and rear?
I'm hoping someone can help me out here.
I just installed the SSD knuckles and c-hubs onto stock Axial diffs with Vanquish 4 link and SSD steering links. My servo is on the diff and I'm using an Axial aluminum servo horn. The steering link hits the servo horn making it not possible to install.
Is this normal with these knuckles or am I doing something wrong?
