We are proud to release the Vanquish Products Hurtz Shifter Dig Unit for the Axial AX-10. This dig unit was designed to be a heavy duty unit for demanding pro drivers. the unit features many details that eliminate known problems for failure. ALL drive dogs are 440C stainless steel including stationary dogs mounted to the housing. Sliding mechanisms will not show galling, so only a small amount lubrication is needed. the dig has 6 points of engagement per revolution. The drive shaft output is stationary and does not slide in and out of the housing. Unit weighs in at 80 grams or .180 lbs. servo mount is located on the dig housing so most servo flex is eliminated. the Hurtz Shifter lever action give a mechanical advantage for the servo of 2.5 to 1 ratio. allowing a standard servo to man handle the shifting demands needed in competition crawling. Production units are being packaged now and all orders will ship this Friday July 3RD, and from preordered hobby stores. Price comes in at $83.99.. cheers :twisted:
Thomas
http://www.vanquishproducts.com/vp-dig-unit-opfr-axial-ax10.html
Thomas
