Well, that model uses the Quad Drive II system, which should be the NV245 t-case. I'm not sure if there is an electronic sensor on the t-case, but you should be able to remove the front DS without any repercussions. However, I doubt that it will help with your gas mileage any. The light weight of the driveshaft (as compared to the rest of the drivetrain) wont create much torque on the engine.
Also, be careful about removing skids....Chrysler likes to use them as mounting points for the drivetrain.
Shaun, this is a rear wheel drive vehicle until the t-case is engaged, then it becomes 4WD.
