roybatty666
Hi All
New to this here forum but long time lurker, I have been playing with a Yeti Score and went a bit mad on the upgrades (full Boom racing etc) but as good as it was on 3s it seemed a bit light so had balance / rollover issues despite numerous suspension tweaks etc.
The solution was a Yeti XL kit :lmao: and it is awesome, even on 6s it rarely rolls as it has a good weight to it (epic power but not as scary as I think people made out).
Having read as much as I can I am being a bit more selective with the parts.
Vanquish Axle (black)
Dhawk front bulkhead / diff carrier (black)
Dhawk ali spacers / shims
Dhawk steering linkage (black)
Dhawk knuckles (orange)
Dhawk hubs (orange)
Dhawk rear axle ends (orange)
Dhawk motor mount (orange)
Dhawk upper rear shock mount (orange)
Dhawk rear upper / lower suspension mounts (orange)
Carbon fiber body panels
Front anti roll bar (sway bar)
Castle creations Mamba X 220kv motor / esc and castle link
Castle Blower fan / heatsink
500k rear diff oil
Spektrum DX4C
coming are:
HD gears (once I see how well well shimmed standards last in the vanquish and bulkhead (I know to mod the HD ones with a dremel)
RPM front A arms
Dhawk front shock tower (orange)
GPM axle trus (orange)
Hot Racing piggyback shock ends
Hot racing upper and lower rear arms
Prop shafts of some kind
HD gears
probably loads of other bits :ror:"thumbsup"
Now my current issue even with judicious use of the throttle and some punch control the stock tyres and wheels are not a fan of 6s. no mater the amount of glue I use the tyres eventually pull off and the tiny 17mm hex mounts compared to the large wheels have cracked one wheel already (yay for the spare on the kit version)
I want to go to Baja 1/5th wheels (desperado rims wrapped in Trenchers) on a 24mm hex but all the conversions just talk of the RTR YXL with its 8mm bolt on axles and using the HPI savage kit, having the 17mm hex on 8mm axles in the kit YXL I am assuming I must be able to get a 24mm hex with an 8mm center bore with a captive pin that I can slap on?
I just can't find any info on this and all the 24mm hex listed online never give you full dimensions. I may go to my local RC shop (they are not great as love airborn RC more) and see if they have any I can test fit.
Hopefully one of you clever lot will know off the top of your head"thumbsup"
Np post is worth anything without a pic or two
a dirty Score
up its skirt!!
Dhawk hubs (orange)
500k rear diff oil
Spektrum DX4C
coming are:
RPM front A arms
HD gears
a dirty Score
up its skirt!!
