Yeti XL Aftermarket Thread
You might need to reset the esc to the radio look in your esc instructions mine did it a few times.It should give you the steps to do it.
Got the Pitbulls glued up and hoping this weekend is nice. I'm a bit excited to check a potentially new spot out, it's an old slate dump that's 1 minute away from a parking lot and positioned on a walking trail. By my estimates it's 40 ft high so I'm hoping it actually works out because I've been wanting a better hill climb spot since the state killed the asphalt pile.
I'd like to make a couple more vids as well. Today is 50-55°F and beautiful out, some the RBs are coming out to play :mrgreen: Just waiting on some 2S packs to charge at the moment.
Well I had some fun for 2 runs but then of course I miscalculated a jump and hit a backhoe stabilizer leg coming right out of a jump, so this happened:
Is that the XL's fault? Of course not, I actually cringed since I figured 20 mph into solid steel would have done a bit more, but I feel I got lucky. That's the 2nd shock shaft I've broken though.
Before that, I let it rip on the frozen pool and that was a lot of fun:
After that I did a couple comparisons with the RBs and Krawlers just to see what was what, however keep in mind the Krawlers have been on the rig since I first got it, so the comparison isn't the best as it's tires with several months vs new out-of-box ones:
Foams: Pitbull stock foams are much stiffer than the Krawler foams, like the difference between some CI stiff vs soft foams. The Krawlers roll over a lot on turns, the Pitbulls don't roll nearly as much.
Compund: Hard to judge again since my Krawlers have several months of wear and the RBs are new, but the RBs still come our of the bag feeling good. Should get progressively better over time knowing Pitbull.
Here's a picture showing the roll. I would get it to about 15 mph and just cut the wheel, which resulted in traction rolling on both, but the PBs were a bit more forgiving and the truck didn't roll over as fast as it did with the Krawlers:
Also, I noticed now that 2 of the 4 screws holding the top of the rollcage on have broken. I can unscrew one of the broken screws but the other unfortunately will need dremeled out or something. If you're gonna be landing on the cage a lot then I'd recommend finding some beefier screws, the stock coarse thread ones are obviously not strong enough for sustained roll overs and then it's worse if one breaks inside the hole.
Nice dude. The PB look like they balloon less also. Still having a hard time justifying the cost.
Yep forgot to mention they definitely balloon less than the Krawlers.
The cost is the only problem IMO. I do realize it's a special tire for what it is but if the cost was below $50, they'd be easier to justify. I also can't compare to the Falkens yet since I've never run those.
I'm so close to pulling the trigger on a set of the RB's but what's been holding me up is whether or not the CI foams are worth the extra cost. I'd really like to keep the ballooning to an absolute minimum and I haven't heard of any feedback yet with that combo.
I tapped my crawlers and falcons and HUGE DIFFERENCE !!! I flipped the tires inside out and installed them back on the rims to keep their form wile tapping. Black gorilla tape and a clean surface and your good!!! I used a light bulb to release the factory wheel glue ..Works great..
Good idea on taping the foams. I hadn't thought of that, still thinking I'll go the CI foams route.
I don't think I'll tape tires any more and instead try the kevlar thread/fishing line route. I had taped my Stampede tires and despite cleaning with alcohol and all, 3/4 eventually let go and now there's several grams of duct tape inside them.
I shot some video today, but half way through the first packs on the YXL, I lost my front wheels and was left with RWD. Haven't checked it yet but it may be my excuse for a teardown with new bearings all around.
30 + runs so far so good.. but im interested in the fishing line idea... If you wanna go into more depth im all ears...I was thinking of folding the tire inside out remount on the rim and super gluing the line in place "16 dots of glue per cord" line.. is that on the same lines you were speaking of ?
:shock:
I can't seem to find it atm but I've seen it on URC and elsewhere where the guys running 6S Truggies were using fishing-line or O-Rings to "belt" the tires. It worked pretty nice but I know the O-rings eventually break and I can't find the particular fishing line used right this moment.
Otherwise, I only got a minute of footage before my front diff exploded, so I dubbed the video a "teaser" since I had planned to shoot at least 2 packs worth instead of a half...The video isn't my best but I wanted to put one out there in case my subs thought I stopped or something, my last upload was 6 months ago.
<iframe width="560" height="315" src="https://www.youtube.com/embed/AjMzhribozc" frameborder="0" allowfullscreen></iframe>
What shocks, springs and oil wt are you running front/rear?
You said the pitbulls dont balloon as much but how much of a difference is it? A lot or just a little? Would it need tape or CI foams to cut out the ballooning altogether?
Duct tape I can see letting go. Gorilla Tape, however, I would be shocked if it let go. I have my front and rears and taped and the stupid stock rims let go before that tape has.
I just ordered a Bomber today. Poor YTL will have to wait for Pit Bulls.
Nice vid Sneetches. I always like your videos.
I second 84yoda on the details of your socks. I think their Losi XXL shocks (from past posts), but I don't know the details. Please let us know the details (spring, oil, pistons). My YXL still seems to bouncing around in the rear. I thought I had it under control but after watching some video the GF took it still looks bad.
Ya my rear end is out of control too, I'm about to put it back to stock springs and oil. I remember seeing a post by brandon from axial on the 1/10th scale yeti saying the lower they went on springs and oil, the better it handled. Makes sense.
