XR10 Bible
Love this thread Eric, this is a great idea!
RcBros makes quite a few parts that work on the XR's even though the website navigation doesn't show XR.
Some items show out of stock, but sometimes an e-mail can sort that out.
Executioner Comp Chassis:
RcBros MOA Executioner V2 |
SCX10 shock parts and springs (uses traxxas big bore shafts/seals):
Shocks | Product Categories |
Knuckle weight holders and brass knuckle weights:
Knuckle Weights | Product Categories |
Carbon Fiber wheels for gluing on tires (both 2 piece and 3 piece):
Wheels | Product Categories |
Extended Steering Arms (to run a straight under the axle steering link) and Servo clamps:
Servo Posts & Clamps | Product Categories |
I'm far from having a ton of knowledge as I am still learning as I build my own xr10.
I know Barry's r/c found in the vendor area has lots of parts, like chassis, links, motor guards, servo cage, and more. He has helped me with my build.
Holmes Hobbies also offers 2 different servos one that is 3s lipo capable 16volt max. I haven't heard much about it but it seems to be pretty slick.
I believe Billet Works Design still has some things, Mantis chassis
Hot Racing also offers parts. Not sure of everything but they have aluminum big bearing gear box housings and motor plates, gears, upper link mounts, and more.
Blue Monkey had a few things as well if I remember correctly.
Hope this helps out some. They are just a few things I have ran across hunting down parts for myself.
Thanks for the input.
If you could do a detailed list, I could copy and paste it into the appropriate sections.
SHV500 Servo
The shv500 servo is suitable for direct hookup to 3S batteries and Holmes has promised to upgrade it to 4S compatible in near future. This affects not only the Servo options, but the BEC post as well, since an external BEC is no longer required.
