Merry Christmas all you crawler hobbiests - hope your holidays are everything you hope for.
I've been home for the holidays, empty-nesters now - all the grown kids were celebrating with their own families in different cities of the west. So I've made good progress on the build - chassis is done, electroncs installed and dialed in, body is done and ready for paint. I need to mount the rear bumper - the one that comes with the body will work pretty well 'till something custom comes along.
It took a lot of hours - more than I expected. I dropped one of those microscopic circlips for the shock shafts and actually found it on the garage floor after a couple of sessions of searching for it. Drilled one hole out on the shock pistons to 1/16th, and the kit now comes with 25wt oil and that's what I had put in the other kit and liked it so that went in this one. They work very well - you do have to shave the rings off inside the slider ring between the two springs. Once you do that they're really smooth.
I moved the bumper in about 10mm and up about 4 so the bottom of the bumper is now about even with the bottom of the frame tubes. Very good approach and departure with this. The body fits very well, and has just enough clearance on the wheelwells on full compression and full articulation.
I'm a little disappointed in the overall speed - thought 3s would give me a lot more speed, so need recommendation on either 27T motor or a larger pinion with the 35T motor. ESC and radio were easy to install and setup although I fiddled with tuning and setup for several hours learning what everything is and does. The settings for the hobbywing are really great. And I get full lock to lock on steering with the tune-able radio. All works really awesome.
Here are modified front bumper brackets by cutting the webbing out from behind the bumper mounting screws and drill new mounting holes so the bumper sits closer to the frame. Only problem is the wheels rub on full lock and full articulation - not sure If I'll need to trim the bumper or not - will see how it does in the rocks. This rig is at least 2" shorter than the K5 Blazer with a wheelbase that is a half inch shorter.
And completed rig ready for painting...
