Welcome to RCCrawler Forums.
The esc went out in my spawn so I got a 40a dynamite brushed esc with a castle 10amp bec for my steering servo and i plug it all in and the esc just blinks red after the three beeps. Any help is appreciated.
I wouldn’t think the steering servo is plugged in backwards, but maybe the esc to receiver? Is the esc plugged into the correct spot in the receiver? Should be channel 2 and the black wire should be towards the outside of the receiver with the white wire next to the channel number.
If everything is hooked up properly according to the troubleshooting, you have low battery voltage or the radio and receiver aren’t bound properly.
Which radio are you using?
Just got home from work and I flipped the plugs on the receiver and everything works now. Except my servo is making a horrible screeching like sound right when it's all turned on. Thank you all for the help!
