Dostradamas
Will this work with the vanquish cms setup?
Did you read page 5 of this thread?
I see clearly some have had to modify
As war as getting rid of that beveled corner, I could have another version of that as well to fit larger batteries.
Would u be able to make it to fit a 3S 5000 mAh?
It is a tight fit, but my Venom 3s 5000mAh batteries fit just fine! "thumbsup"
Put me down for a rear cover!
Alrighty gang, we're going to augment the waiting list so theres no confusion when we PM everyone for availability and fill orders "thumbsup"
Name/Screen name/Item(s) you want ie; front box, rear drop box with or without flat cover.
Please copy and paste this list when you add your name to the list so we can keep track of everyone. We get ALOT of PM's to plow thru each day on top of running the shop and this will keep everything in line, thank you guys for your understanding "thumbsup"
Seems pretty simple to me...
As promised here is how I heat molded my box to make hard case lipo batteries fit - just get a heat gun on the outside of the lower corners on low setting. As soon as it gets pliable press a hard case Lipo into the corner then run cold water over the abs plastic to set the mold in place. Worked great! Just be sure to keep water off your battery.
Also be careful when trimming the abs - it tears much easier than lexan..
Got mine and fitted it today. A word of caution some of the corners get pretty thin from the mold. I ripped mine some when I drilled the holes to put the cross brace through. Other than that very pleased. Lookin forward to getting the rear.
